Full Pillar Pods For "01"
recall check
Valve Adjustment-Columbus, Ohio
Is there a company that makes a full pillar pod for 2001 trucks that have the tweeter mount in the same location? I want to get the full for a cleaner look but will deal without it if not avalible. Any information on this would be helpful.
One other thing is what are the part number for a matching set of 60 PSI boost gauge and a Pyro from Auto Meter
Got One
They do make them... kind of. They are meant to be a cover for the stock one but they work by themselves quite well. Here is mine
3 Pod?
Bad,
If they're meant to be a "cover", what's the difference between them and the stock covers? Would hate to look "unbalanced" in the cab.
Also, do they make them in a 3 pod, and is their 'agate' color the same as stock?
Yes they do make them in the 3 pod version and the only difference in the apperance is a slight grain diff. in the plastic. They dont make them in any other color than black so you have to paint to match your particular interior color. The Agate color can be purchased at you local DC dealer and the part # is 82201399 code LAZ.
a-pillar
Just a suggestion, use the a-pillar as a replacement rather than a cover, it looks much better and you don't have to chop up your stock a pillar. It only take one screw at the top and a screw cap painted the same color as the pillar to hide the screw. Like someone said the grain is a little different but once it is painted you can hardly tell. Look up the auto meter web site you can check out all there guages and pillars and decide what style you like. See my profile for what I used. They work and look great. Good luck. Dwayne:cool: :D :)
