Stefan, I called and spoke with Bill on Friday afternoon. He did recommend a noise filter, so I have bought one from you and it is in route. I am just curious about why it only mis-shifts at WOT going into overdrive, not TC lockup. If I turn overdrive off, it does just fine, otherwise when it shifts into od is't almost like it hits neutral and revs to the rev limit repeatedly until you back out. I've only done it 3 times thus far. Twice the nite after the DD box install and once after I talked to Bill and I cleaned and greased all conn. and re-cal the TPS.
I don't mean to come off upset or ill. I am extremely happy with the DTT transmission. It has peformed just fine up until this week. I have made a handful of changes in a short amount of time.
I installed DD3's 3 days prior to the transmission work. This week I replaced trans. fluid and filter only, made no adjustments whatsoever. Two days after the fluid and filter I removed the EZ and replaced with the comp box. I had no issues at all until the comp install.
