The FCM mounts behind the fuse box, next to the fender. It plugs into the fuse box and is held in with 4 screws. Remove the FCM, clean all connections, and ever so slightly twist the flat pin connectors to insure a good connection before you invest in a new one. If this does not fix the problem check online for the best price,most likely about 40% less than the dealer.
