2nd Gen Non-Engine/Transmission Fuse hot
Engine/Transmission (1994 - 1998) exhaust 4' vs.5' with twins
Engine/Transmission (1994 - 1998) Power Loss
Is there an easy way to find out the hot side of the dash mount fuses? I have some fuse taps and need to find the hot. Guess I could break out the test light!
Nick
:eek: I would not use a test light on the truck it can cause a surge on the power source that could damage electronics in the truck. Use a volt ohm meter it is much safer. Best of luck.
