Fuses
C/B coax routing idea? But how too?
transmission shop
ok first of all... .
i would really like to thank dodge for having the only fuses in the power distribution area that you can't buy at the auto store... thereby leaving me completely stranded...
for those of you who haven't found out yet... all of the little fuses in your engine compartment can only be bought at the dealership for $3 a piece...
and second of all since i blew the fuses trying to rewire my air horns does any one know of something that can be plugged into the fuse pannel to accomodate all of the wires that come in from modifications?
thanks and sorry for the long post
jason
2001 3/4 ton driftwood 24 valve HO 6 speed; silencer ring out, Glasstight cab high shell, Practical Solutions high idle kit, JRE 4" exhaust, Hadley Bullly Air Horns
Alpine CD player, Kenwood 750 watt amp, 2 10"
JL subwoofers custom truck box behind the seat. My Truck
Jason
If you're talking about the small red, yellow, blue, and other fuses in the PDC, you should probably try a new auto parts store. Radio Shack also carries them.
Good luck!
I bought those little sqaure basterd at an autoparts store. I had to go to THREE of them but i found some. For a temporary fix you can take the clear cover off and twist the two wires inside together. Good luck
Clark
I installed a Painless Wiring kit from Geno's right after I bought my truck. I got the interior unit. It has 3 hot and 4 switched circuits, or vice versa.
99 2500 QC 4WD, AT, 3. 54 LSD, Forest Green, Mag-Hytec diff cover, Amsoil 75/90 Series 2000
I have a box full of the regular sized plug in fuses but when I blew one in my 99 I was glad Dodge included 3 spares on the fuse panel cover. The local auto parts stores all carry the smaller fuses here in FL.
1996-3500 4x4 extended cab tst #5 plate, K&N air filter,Primeloc fuel filter kit,4" exhaust,Purodyne bypass oil fiter system, bigger injectors (215),b&m trans pan,Amsoil all around,temp gauges out the wazzo, much transmission work including TST upgrade kit and Bill Kondalays TC, Transfer Flow 98 gal bed tank,double tow 33' 5th wheel and 12' trailer w/motorcycle(Honda Valkyarie Interstate)Also have 1999-250-stock.
Installing governor spring kit(BD)on dualie.
