Yes, your truck has two fusible links. Both are in the wiring between the battery and the intake air heater relays.
To unplug the VP44 wiring harness connector, you first must slide downward the bayonet style lock which is built into the connector. If the connector has a lot of baked on grime over it, it can be difficult to move the lock the first time.
Good luck,
John L.
