I think most people have made it clear the main reason they own a Dodge is because of the Cummins. It is the best diesel engine out there. Whethter you like Chevs or fords or not(most of you do not to the point that rational thinking goes out the window) they both have a better automatic transmission than the Dodge does. The 48RE is better but you still need a lockup switch, the converter is still weak, it's a 4 speed and doesn't have a tow/haul mode. I love the Dodge truck, not because it's a Dodge or just because it has a cummins diesel but because I try the others and it is superior in almost every way. That being said I'm driving an 03 Ford with the 6. 0 with the 5 spd. auto transmission as my work truck right know, I also have 03 and 04 Dodge diesels, I have had no troubles with the engine or transmission YET with 20000 miles. The transmission works great, the motor has good power once you get going, there is alot of lag on the bottom end and it's no cummins. The rest of the truck well it's no dodge. My point in all of this is Dodge makes the best truck, has the best diesel motor but has the worst automatic transmission,it's about time the change that . Of course that's just my opinion and in the grand scheme of things that probably doesn't mean s**t.
