FWD front axle vacum motor
Foam From Vents?
Skykacker front springs and rear ride height
Had one on my 98. Water would get in the push pull cable and freeze up. When it warmed up everything worked fine. I went back to the oem with hubs. A lot more dependable.
I purchased a GM vacuum control switch (HVAC) from a wrecking yard for $5.00 and mounted it under the dash for operating the CAD unit. I disconnected and plugged the vacuum valve on the transfer case. I did this when the truck was new. @NIsaacs , I have 2 Lo and the CAD is OEM with over 350,000 miles as well.
- John
The Posi-Lok worked really well for me til I swapped to a solid axle. I will be posting it in the classifieds when I get a chance.
