I recently have been towing in the 10-12,000 lb range and have noticed a noise that I have not heard before. As I approach a uphill in full boost, full throttle, 5th gear 1800-1900 rpm, then downshift to 4th and apply full throttle, I immediately get a FWUP-FWUP-FWUP noise, (at 3-4 FWUP's per second) and this will continue until I let off then gently roll back into the throttle. There doesn't seem to be a reduction in performance and all gages, including boost, look normal during the "noise event". I check the post turbo hose clamps every oil change so I'm pretty sure this is not a loose clamp..... any ideas??
