Hey guys,
I don't post here that often, but I just finished installing my front suspension (lorenz 2. 5) and at the same time I put on the 1999 HD t steering.
I had read on the board (after I had it all together of course) that there was an issue with the 2001 pitman arm-end tie rod end being a different dimension than stock. The pitman side rod end that is spec'd out on some of the lists you find via a search, will not work with the 2001 pitman arm. As mentioned by others there is a different taper in the TRE.
All one needs to do to make it work on a 2001 is to substitute the P/N on that list for your STOCK pitman side TRE. The threads and shank are identical, but the taper is obviously the right size for the 2001. Luckily my old one was still brand new, and now I have incredible steering.
This may be obvious, but new TREs on a t style steering, plus DSS, plus fox stabilizer, plus stock like angles, plus 2003+ style tracbar, and lorenz swaybar links= one extremely tight and responsive dodge ram truck steering.
I dont think I have felt a new vehicle with tighter/nicer steering.
By the way, and I will shoot some pics and do a write up on the install, the lorenz 2. 5 suspension system (at least the front since I dont have the rear done yet) feels incredible. I just ran down to the store and went through a parking lot with some ridiculous speed bumps just to get a feel for how the shocks behave etc. You can hardly feel the bumps..... until the *** end rolls over it! Then it jars and wants to send you through the roof. The front is absolutely night and day though.
