FYI Automerer 2646 EGT not recommened for diesels
DTT's New Torque Converter
EGT Probes??????????
The earlier thread on egt probes got me think ing about the 2646 that i was sold by one of this sites advertisers. I called Autometer a few min ago and asked them about the gauge and probe #'s. They said that 2646 kit was not reccomended for diesel application. Accuracy +/- 200 deg and probe would not hold up well to diesel ex. particulate erosion. If one was used it would have to be post turbo.
They recomend 2 1/16"gauge #3365B ( "B" is black bezel, black face/ red pointer) with probe #5244. this setup is 0 to 1600 deg +/- 25 deg
2K, 2500,Laramie,Quad,4x4,3:54LSD"slushbox 250 RPM drop WOT shifts", , reese 15k 5th slider, LAVERNGE BULL BAR,WESTIN NERFS, TA's, DD1's, VA, boost & elbow onboard, 4" & 9000's in transit w/more to come
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA,VFW,SASS
[This message has been edited by JNutter (edited 09-30-2000). ]
<font color=blue>Always use the probe #5244! If you compare it to the others you will see that its a much more quality piece. And yes it costs more..... I think mine was around $80.
Also always use a 0 to 1600&deg; EGT gauge... a 600 to 1600&deg; is useless when you goto shutdown. <font size=-2>
[This message has been edited by KatDiesel (edited 09-29-2000). ]
I agree the Autometer #2646 is not for our applications. Its the 600-1600 degree gauge & thermocouple combined. It will be useless. Somebody should let Bullydog know.
I have what Kat is running. Autometer Ultra-lite P # 4365, 2 1/16" 0-1600 degrees, w/ thermocouple # 5249.
Kats T-Couple is the better one.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
