FYI Dead accelerator pedal
service manual
Water/Meth on 3rd gens
Backed out of the drive this AM, put it into drive from reverse and had NO response from the accelerator pedal at all. Limped it back into drive in idle. Turned truck off, restarted and had full pedal back.
Do not know if anyone else had similar occurance but sure am glad it was not on an on ramp towing my trailer!
Yep same problem. There is a reflash for it;www.dodgeram.org Tsb#18-027-03. If it does it again just put it in neutral for a sec and back into gear and it should be good to go!If you give it a sec before you hammer down it will work most of the time.
