I have a 2005 DA3500 with a G 56 transmission, this transmission has had an overhaul under warranty at 50,000 Kilometers or 31,000 miles for both bearing noise and high torque chatter going from 4th to 5th gear.
Now this transmission has failed again, both 4th and 5th gears show high heat and wear and the syncro at 4th-5th gears has blown and bonded to the main shaft. the oil smells worse than elephant puke.
Have bought new factory G 56 and this transmission shifts fantastic as a transmission should and nowhere like the old one. has anyone had this problem, as Chrysle has said take a hike. I need to know what caused the this failure.
The only causes that I can think of would be a bad case, or the CNC work is off slightly.
Does anyone out in the mechanical have any ideas as I am fresh out, and no new thoughts.
Help Help Help
Help Help Help
