G360 4x4 I think ---
electrical grimlins/pulsating lights
Plymouth RoadRunner horn install (for the completely bored)
I may have stumbled on one of the reasons that the 4x4 trannies get in such bad condition. With the rear of the main shaft supported by the engagment into the transfer case, the pocket bearing can go out and shed metal into all the working parts before the transmission acutally dies in the road. The additional support holds the main shaft in a workable position as the pocket bearing continues to erode to nothing. I have some pictures if any one is interested, of a recent tear down that turned out to be non repairable due to the expense of parts. Bottom line, if you want the transmission to last, you might want to check it from time to time as to preload on the shafts and inspect the magnet in the bottom and if there is ANY black metal flake, stop using the truck immediately.
Some times the input and main shaft are fused together by the pocket bearing and in those cases, the problem can't be run on. Actuall less damage than if it continues in service.
James
Edit spelling error, not my long suit.
Pictures
Frank, send me a current PM and include your email address. I will forward the pictures that Paul sent me. There are more that I feel sure he would send directly to you. We were going to repair this transmission and as it came apart, it was clear that it wasn't going to be cost effective to repair. If all you need is syncros, you can do that for sure. The worst part of the job is the r and r on the unit. It is a heavy booger. Which syncro is weak on your transmission?
If you decide to tear into your transmission, I will be available to advise on the job. The pictures Paul made are good and will allow a point of reference to discuss the work.
James
