photowrite
Is anyone aware of recent changes to the clutch and/or flywheel on G56-equipped trucks, specifically after 2014?
This past Saturday I bought a new, 2017 Ram/Cummins 2500, regular cab with G56 transmission. This is an addition to my fleet, which includes a 2014 Ram/Cummins 2500, crew cab, also with G56 transmission. The 2014 has about 40.7k on it, and has always had a nice, perfectly smooth clutch that modulates well (with zero accelerator/fuel added). So nice in fact, that my alignment guy commented on the clutch when he pulled it onto his rack (when new in ‘14) for my baseline alignment check.
During my brief test drive of the 2017 this past Saturday, I did notice the clutch was a bit grabby/abrupt when it hooks-up. It wasn’t bad enough that I wanted to abort the purchase. (I'd made a long distance telephone deal, great price, and wanted to buy ‘this’ truck. Pretty hard to find a reg. cab G56.)
As of today the 2017 has about 400 miles. I drove both of my G56 trucks back-to-back this afternoon, and confirmed the difference, I’m confident it would be quite noticeable to any proficient/expert operator of manual transmission/clutch machines. I don’t wear clutches (or brakes). My question/complaint/comment is about low-idle engagement (no added fuel) in first, second, and reverse.
With many/most stock clutches there is a nice, smooth grey-area where the clutch has yet to fully engaged, nor disengaged, and a good driver can move the pedal either direction and there is nothing rough Like might be needed for slow control while backing a trailer in tight quarters, etc. Adding rpm and adding slippage can help, but is not a solution, and actually increases wear and offers less control for low speed work.
No matter how smooth I am, at the point of engagement, the 2017 grabs and jerks some, and if I try to keep it in the ‘grey-area’, it sometimes starts to buck and jump a little more.
It feels like how I’d imagine a clutch might feel without a dual-mass flywheel (though I don’t know, haven't driven one without a DM flywheel), almost like the engine idling pulses are being transferred instead of being absorbed it that makes sense. Of course there are always differences between similar, though not identical trucks, but something doesn't seem right. I use/slip the clutch very little, but when I do I want it to be smooth.
When I have time, likely in a few weeks, I do plan to have a dealer cut/program a couple extra keys, and will mention it then.
G56 clutch changes? Grabby on new ’17
Thanks for reading and opinions/input if you have something.
James
James
