G56....fill Plug/drain Plug Size
AirDog 2 Micron After 25000 Miles
Spotted same leak on new trucks on the lot
May I semi-hijack? Regarding the fill/drain plug locations on the G56; If one is lying beneath the G56 looking up, and right is front and left is rear, is the drain plug on the bottom center of the seam of the casing? Is the fill plug more forward, but high up, near the bend in the exhaust pipe? I'm tempted to change the ATF4 but not sure where to add it and if I can get six quarts in it. Thanks and excuse my worming this in.
Yes, drain plug is on the bottom just in front of the crossmember and the fill plug is the one on the passenger side... . the 14mm allen plug, not the large Torx plug at the top.
Joe
