comrades - last fall i tossed the factory clutch and installed south bend single disc w solid flywheel kit. the clutch is great. i refilled the trans with amsoil atf plus 4. everything is fine - just some gear noise. south bend states that this is normal. i get that. question is , can i put in amsoil 75w90 trans lube and still shift my truck in the cold. like zero cold? i am looking to quiet down the gear noise a little bit. thanks in advance for any suggestions.
here is what i am considering :
https://www.amsoil.com/p/manual-transmission-transaxle-gear-lube-75w-90-mtg/?code=MTGPK-EA
cheers!
cheers!
