G56 swap harness help
Bad luck lately
Code P0101
Just swapped in a g56 into my 07.5 ram from 68rfe auto and I had litteraly everything perfect to swap from a burnt truck minus the trans harness. Well I got truck started with a efilive manual trans tune set and started wired up on a push button, but I am curious as I still want to wire everything properly what years can I use a g56 harness out of and also for clutch pedal position sensor does my factory dash harness have a plug in for it? If so where at. Also if anyone has a g56 harness or knows where to find one I would greatly appreciate it.
