G56 transmission Is not a Getrag
Anyone running Powerbypoole.com twins??
oil/fuel filter changes
SnoKing
Read about the G56
NV5600HD Six-Speed Manual Transmission
A six-speed manual transmission is available only on Ram
2500/3500 when powered with the 5. 9-liter Cummins®
600 Turbo Diesel engine.
G-56 Six Speed Manual Transmission
At the mid-year mark the DaimlerChrysler CVD G-56
manual transmission will replace the NV5600 on RAM
2500/3500 when powered with the 5. 9-liter Cummins 600
Turbo Diesel engine. The G-56 six-speed manual
transmission will also replace the five-speed NV4500 on
Ram 2500/3500 when powered with the 5. 7-liter
HEMI V8 engine.
Like the NV5600, the G-56 six-speed gearbox also features
close-ratio gearing, eliminating the “gaps” between
second, third and fourth gears found in five-speed manual
transmissions. This allows the driver to match road speed
and engine rpm more closely for improved performance
and fuel efficiency. The six-speed’s close-ratio gearing also
improves trailer-towing performance on grades, as there is
less speed and rpm drop when the transmission is shifted
to a higher gear. The lower ratio first “creeper” gear
improves launchability when fully loaded or when towing
trailers.
Ram 2500/3500 trucks equipped with the DaimlerChrysler
CVD G-56 manual transmission and powered with the 5. 9-
liter Cummins 600 Turbo Diesel engine also include an allnew
dual mass flywheel which greatly improves NVH
performance. The Self Adjusting Clutch included with the dual
mass flywheel maintains lower clutch pedal efforts for the life
of the clutch.
This is from This
And the 2005's are back to 600's????, is that how they solved the drive line vibrations? LOL/LMAO
SNOKING
On the clutch end of things, we all need to thank Luk for this clutch system, being a dual mass flywheel and self adjusting pressure plate. Luk got the OE with Ford 6. 0 liters and the Duramax and put this same design clutch in these two vehicles. The duramax flywheels were failing within 30-40,000 miles so Luk tried to scrambled and redesign it. In the Ford dept. they could only put them in the F250 & 350s because they would not stand up in the 450 & 550s. We found that we could put the F550 solid flywheel into the 250 & 350s. This helped but did not resolve the issues. The biggest problem being that these systems will not tolerate inhanced power and torque. We will get to work on the clutch system ASAP. I will be ordering, when and if available, the complete clutch package for the G-56 trans. and start to work on redesigning a whole new clutch system that will accept the power enhancements.
Peter
Thought you guys would get a kick out of this. I called the dealer to order all the clutch parts for the G56 manual transmission...
Flywheel... ... 5018079 AC... ... $1356. 60
Clutch Disc... ... 52104725 AA... ... $333. 90
Throwout Brg... ... 52087514... ... $123. 48
Pressure Plate... ... N/A... ... Not available
Grand total of $1813. 98 and that is without the pressure plate.
I better come up with something quick!!!!
Peter
Peter,
Any Idea yet if the 13" flywheel and clutch set will work with the G56? The ConFE that I got from you 3or 4 years ago to go in my 2001 is still going stronge, but then again I'm no where near it's max.
Kevin
