I did a google search and search on here. In 5th gear only at around 1500 RPM, pulling a trailer or not I have a gear noise. I read up on the "gear roll over" and I don't think that is it. All my gears low,2,3,4,6 are all tight. As when in that gear I can't move the gear shift lever at all with engine under a load or not. When I put it into 5th I can move it forward and back almost a inch with load or no load. All gears shift like new and slide right into place with no effort. The truck has 58k miles on it and all stock. I can't seem to see anywhere where there is a shift detent in the rail like the NV4500 or 5600 had. Does the shift rail need to be replaced, or the 5th gear syncro or the actual shifter? What holds these transmission in gear? Thanks for the help.
