gages for 05 dodge cummins
Where To Mount The Attitude Monitor??
Which injector with a hx40?
Wear is the best place to hook up lights for gages on a 05 dodge also witch is the best place for the thermo coupler on the exhaust manifold
Getraub and I have ours post turbo. Jengle has his pre-turbo. As were pulling a small hill going to the fall brall we each had temps within 30 degrees and I was running stock.
As far as the lights, find the wire that dimms your dash and splice into that and you will have dimming gauges
Just finished installing the Westach combo gauge. I drilled and tapped the exhaust manifold by the #3 exhaust and used the #2 wire behind the light switch. Worked real good.
