I have used 2x4's spaced with 2x4's.
Deck screw a 2x4 (4" side down) then temporarily lay in a 2x4 standing verticle (the spacer) then another 2x4 screwed (4" side down) then move your spacer verticle 2x4 over alongside your new screwed in one, then screw another one down flat, then ..... Wait till studs go on sale at Home Depot to get the lumber. Cost $1 / stud, 3 studs wide (3 1/2, 1 1/2, 3 1/2, 1 1/2, 3 1/2) = 13 1/2" x 8' (basically 8 sq feet of storage) = $3 (about $. 40 / sq ft) + screws.
I have done this for about 4 different homes (16 " rafter centers) and have never had a moisture buildup problem, had pleanty of strength, can easily walk on the decking without my foot falling through, can get the lumber up through the scuttle hole easily, is a one man operation with a screw gun.
Like mentioned above, do not forget the lights. I use a drop light hooked to a hook in the rafters and drop the electrical cord down through the scuttle hole and plug it into an extension cord then into a house socket when I go up to get something.
If you also use an extension cord, then you plug it in, take the end with you, plug in the drop light when you get up the hole, get what you want, start back down the hole, unplug, put the drop light end where you know where it is next time, cover the scuttle.
Bob Weis
