Details here: TDR Privileges
Jim, yes you are right, I make MPEG or WMV files. This one came from the guy that made it for TV. You may need to update your quicktime application which you can do online for free. I had to to see it. (but I could hear it) :-laf
I'll see if it's ok to convert it then see about getting the application to convert it.
Does the program you use for converting formats have an option for "VBR" or Variable Bitrate? If it does, using VBR will reduce the filesize significantly.
