garrett ball bearing turbo
Installing a temp sending unit in transmission oil pan
Hard Start ... What Next?
just bought a garrett ball bearing turbo that was used on a 03 duramax and i am trying to figure out the specs on it, wanting to run it on either a 06 commonrail cummins or a 90 VE cummins. the only thing i know is that it was bought from turbo exchange in charlotte, nc and supposedly?? has a 18cm2 exhaust housing, but who knows. it has A/R 0. 72 and in circles 05 and 35 stamped on the compressor housing. the tag has a serial number of JJM54494 and a part number of 766172-0001 and on the the turbine housing it has in circles 326 and 05 stamped and at the flange (t3) has A/R . 99 and m3. what are the specs? will it be laggy? and how loud do they whistle??
ok, found some info but still not enough this is what i have
766172-0001 - Turbocharger Kits - Applications - TurboMaster
PowerMax Performance Diesel Applications
considering putting this on either my 06 or my 90 that currently has an hx35w from a 01 H. O. question is can i change exhaust housing to use with my jacobs brake on my 06 and if so would this be laggy compared to my stock he351 or hx35w? does any one know what size compressor wheel it has i know the 06 has a 60mm and the 90 has a 56mm, and also what size exhaust housing that is?(which would probably have to change anyways if going on my 06 and hook to 4'' jake brake) do they whistle hard ( or at least as loud as the H. O. turbo on my 90 which SCREAMS!!)
