Archived Gas in Diesel Engine
Archived Possible vp44 failure but have other concerns
Archived 01 injection pump?
Did you run it? If so drain the tank and all the lines. If not you should be able to get away with just draining the tank
Just drain the tank and change the fuel filter fill with diesel. I also added a quart of non detergent oil to a full tank. Hope this helps.
Jim
