"Mad Max"
Hiya peeps -
Need clarification. My '78 Ramcharger has a factory 35 gallon plastic gas tank, and I'm converting the rig to EFI.
There are three openings in the tank: One for the sending unit, another in the top front for what I think is the vapor canister vent or fuel filter return(?), and the third is of course the fuel fill.
The sending unit has 4 'openings': the standard 5/16" line, the negative (ground) terminal, the fuel level terminal, and a 1/2" vent that goes to the filler neck.
The vapor vent(?) is a 5/16" hard line reducing via 90* bend to a 1/4" hard line going through the tank via a rubber grommet - not a 'hard' seal.
The fuel fill is simply the gas pump hose opening and the 1/2" vent line (that connects to the sending unit 1/2" line).
Two questions:
1) Is the 1/2" line the vent for both the tank and the fuel fill operation (via the gas cap)?
2) Can the 5/15-1/4" 'vent' line (with the rubber grommet) be used as a return line for an EFI application?
Here's what I've already done:
- Original sending unit 5/16" line replaced with 3/8" line along with incorporation of in-tank 12v 50 psi EFI pump (completed yesterday)
Bottom line: I want to use the vapor vent as the EFI return line, and leave the 1/2" line (for the filler neck) as-is for the vent for the tank (which may already be the case, I'm just not sure, and the factory service manual does not cover the vent process).
Thanks amigos,
- Sam
Two questions:
Thanks amigos,
- Sam
