I just bought a 96 dodge 2500 that was changed from a 360 gas to a cummins. I heard that you have to disable the fuel pump that is in the tank or you will blow the seals in your injection pump. Is that true and if so what do I have to do to fix the problem, I took out the fuse for the fuel pump. Would that be good enough or will that restrict the flow? Its just sitting right now because a few things need to be finished, I want it to be exactly right before I drive it too much. I believe the engine is out of a 94 or 95, the plate is gone so I can't be sure. Anything else I need to know?
