It appears considerations of fuel-boost relationship is very different between turbo charged diesels engines and gas engines.
In a gas engine like my twin turbo Supra, If you added boost, you better be sure you had a fuel map rich enough or bigger injectors to support the additional boost or you could lean out, exhaust gas temps would sky rocket and you could detonate destroying pistons.
It apprears that diesels are a very different animal. Instead of more fuel enriching the charge and cooling things down, to avoid a lean/ detonation issue as is the case in gasoline turbocharged engines, the extra fuel injected into the diesel will increase chamber heat-ignition... .
Adding air or increasing boost actually cools down the charge (to a point i gather) and exhaust temps decline. exact opposite of gas turbo engines.
The reason I am seeking to understand this is I was considering 275 injectors, but SuperChips recommended against it. Purely defensive medicine I am sure, as the richer injection could raise Exhaust gas temps, without other compensating factors like better exhaust flow, cooler better induction and/or more boost.
Am I understanding this correctly?
