Engine/Transmission (1994 - 1998) Gasket set and washers???
Engine/Transmission (1998.5 - 2002) An Unlock Mystery Switch
2nd Gen Non-Engine/Transmission Steering pull to the right
Anybody know where I can get a head gasket SET with the Cummins marine gasket (#3283339)? I don't want to buy the stock gasket set and then buy the marine head gasket and have two head gaskets.
Also, where can I buy the copper gaskets that go under the injectors and the rubber gaskets around the injectors to put my stock injectors back in?
Also, I need the o-ring and copper gasket for the #1 delivery valve.
97 4x4 SLT 12 valve ext cab auto/ #8 plate/ 3k GSK/ straight piped/ Greg Hogue cam/ DIY head port/ head studs/ DiProcol Optix gauges/ Lukes Linked/ 35" Claws
Not sure where you located at but I would call your local Cummins parts supplier and get the stuff from them. I get all my Cummins parts from Cummins West in Bakersfield, CA. You should be able to get just the head gaskets and your injector washers from Cummins. You don't necessarily need the squared rubber o-ring for the hold down nut, all it does is keep water and stuff out of the injector bore.
You'll probably have to find a diesel injection pump place to find any delivery valve washers or o-rings. Cummins doesn't carry parts for the P7100, at least my parts supplier doesn't.
Joe
From what I understand, the HG kit only comes with the stock thickness HG. If you want the . 020, it's extra. It doesn't come in a kit. *Some* Cummins distributors will trade or buy back the stock HG in the kit for the . 020.
www.scheiddiesel.com can get you your fuel injection needs - copper washers, o-rings etc.
