I removed the upper intake manifold in order to install DD2's and I discovered there was no gasket on the bottom of the heater-grid! Is this OEM or a Cummins factory screw-up? Seems to me that this is a place for intake boost to leak. (Mopar-Muscle said there should be a gasket above and below the grid heater)
Anyway, I'm going for a 'Dynojet' run tomorrow afternoon, and want to know if I should postphone my run until I get the bottom gasket installed?
Thanks, Bob
Y2K Black 3500 ISB 4x4, 4:10 LSD,Auto,QC,SLT Laramie,"EZ",DTT VB,DD2's,LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Thanks, Bob
