Gasser Header Wrap For the Cummins?
Oil analysis
Pyrometer and Turbo boost Gauges
Would there be any benefit of Using Header Wrap on the Turbo(hot side) and Down pipe on our Cummins Engines?. The Theory of the Header Wrap is that it will Keep the exhaust gases hotter as its moving down the pipe creating less back pressure. The Local Muffler shop said that I would Melt the Turbo!. I dont Believe it. Any thoughts?
Doug.
1998. 5,2500,ISB,Auto,CC,4x4,White Sport,275hp Injectors,240hp to the Ground,16x8 Eagles,295 BFG's,2. 5" Skyjacker Lift,Stockland Seibring Shell.
[This message has been edited by DieselRam (edited 06-18-2000). ]
Doug. . Header wrap would burn off in time,when i did my 5 inch exhaust i Jet-hot coated it, Now that i purcahsed the HX-40 i want to the exhaust part and the exhuast manifold ... JB
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors and boost module,HX-40 16cm,here and waiting to fab-up a a new adaptor,Next Jet-hot the exhaust manifold and turbo housing,..... finally a blue box or TST box or?????
DieselRam, the keep the exhaust manifold hot theory is supposed to improve turbo efficiency. Keep the gases expanding until after they exit the turbo will allow you to better use the energy being released.
Take a look at my turbo cover, it is about 1/2 way down on the right. The pics take a while to load.
Turbo Cover
I have had Moroso header wrap on my ram for three years and its in as good of shape as the day I put it on. I have got a very low stall converter so I need the turbo to spool up as soon as it can. The wrap did make it spool up sooner. Now I have put a Geno,s Garage exhaust blanket on top of the wrap haven;t got a chance to drive it yet but it sure looks good
DOUG!AirBulldog
I had header wrap on mine for 3+ years as well, I took it off when I installed my hx 40 and am going to put it back on, when I origanally put it on it made 1 lb boost more,
Adam
96 4x4, 3. 54 posi, 3" lift, 35" bfg m/t's, aluminium wheels, sport headlights,billet grill, tenzo blue foglights, K/N, NOS, Bullydog LPG, Tweaked Pump, Hx40 w/ 18. 5cm2, 4" exhaust w/ 2 chamber Flomaster, Jim Leonard street dual disc, Kenwood sterio System, Westach 60lb boost/ egt guage,aluminium bed rail covers, clear tail lenses w/ red bulbs, soon #10 tst and 370hp marine injectors, best performance to date= 428hp @ 2400 and 937lb of torque, and 14. 35 @ 98mph, more to come, Adam
Doug is right. I have had Thermo-tech exhaust wrap on my downpipe & Turbo outlet for 3 years. Still Looks brand new.
I put a 4" JRE exhaust on recently. I had Geno`s exhaust blanket and the exhaust wrap on the OE pipes. Didn`t bother putting exhaust blanket & wrap back on. Figured it didn`t do much.
Wrong! Popped my hood one day and couldn`t believe the heat that was radiating from the exhaust side of the engine. My Psychotty induction cone was VERY hot.
This morning the exhaust blanket & header wrap were put back on! #ad
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
[This message has been edited by HEMI®Dart (edited 06-25-2000). ]
For another opinion on this topic check out my post in "GENERAL DIESEL". The thread is "How hot does the turbo housing get?"
Tom
96 2500 E-Cab, 4x4, 5sp/3. 54, NRA sticker, etc.
[This message has been edited by RT66DOC (edited 06-26-2000). ]
