Gauge change
Blown HX40, need a 4"exhaust v clamp
Fiberglass or Metal Antenna
I'm currently running autometer boost and pyro gauges, and I've been thinking about changing to an SPA combo. Does anybody know if any of the existing hardware / holes can be reused. I am worried that the pyro probe will most likely be a different size and make the conversion difficult if not impossible. Anyone who has done this conversion or researched it, please give some advise.
Thanks!
Otis
Hello
I havent done this, but from following guage posts, you should be able to swap guage brands ok if enough wires are there. Some EGT guages use an amplifier, some dont. Brand of probe shouldnt matter, a pyro probe and lead set should be interchangeable from what I have seen, but I dont "know" the answer here. Guage mounting hole size should be fine, if you use same size guage, brand should not matter. I have a ISSPRO boost and VDO pyro, and either will fit in the others location.
I know, not much help!
Eric
