Removing the dash trim panel on the 06 is not necessary. There is a triangular shape side access cover on the driver side of dash. Door must be open. Panel just pries off. Dimmer harness is right there, but you cannot access the pin connections to test them. There are two (2) orange wires with brown tracer, same as 05, but pin number has changed (#2 I think). Use a multimeter with a sharp probe or gently slice off a little bit of insulation with pen knife. 50/50 shot. Complete the circuit to ground. Headlights on. I got the wrong one at first: Rotating dimmer read inverse voltage (about 1. 5 to 5). This one goes to a lamp circuit. The other one, from the resistor bank, is the correct one. Rotating the dimmer reads 12 volts to 2 volts. There are a couple of convenient philips screws there for your ground connection.
