Gauge Install - dimmer/backlight
Anyone Work At a Dodge Dealer?
weather tech floor mats
Well I got the backlight on my Isspro EV2 gauges hooked up. Not the way that I would have preferred which was to hook it to the OEM dimmer circuit but the dash backlights are now LED running on 5V. What I did was to tap into the cab clearance light circuit for a switched 12V supply. Then ran it through a 50K pot so I could adjust the Isspro backlights and then onto the gauges. Since I don't adjust the dashlights that often this has worked out nice.
Kevin
I have my Isspros run through the dash dimmer on my '07 but have never found a need to dim them. Genos gave me instructions w/photos when I bought mine.
Where to mount
i have been wanting EV2 gauges as well but have not been able to find a gauge mount yet. Guess I will just have to wait till somebody comes out with one.
Geno's has a tripple A-piller which is what I used, you just need to get a shorter bolt or cut the one that comes with it.
Kevin
