I am continuing the installation of my SPA gauges in my 2001. 5 2500. I have put in the boost and EGT sensors. Now I need to do the transmission temp and Fuel pressure.
1) I bought the crossover line from DTT. How do I find the proper crossover line to replace with the DTT line. Is there any trick to the install or just replace the line, screw in the sensor, and check the fluid.
2) For the Fuel Pressure, I purchased the new FP line from Geno's. Has anyone installed with this? Where is the Schrader valve (I am obviously new to this). Can I just screw in my pressure sensor or do I need to adapt anything? Where (and how) should I mount the sensor on the end of the line.
Thanks for all the help. I couldn'd do it without you all.
Levon
Levon
