Engine/Transmission (1998.5 - 2002) Gauge Install Question
Engine/Transmission (1994 - 1998) EGT shutdown temp?
I am in the process of installing a set of gauges. I am using the overhead gauge mount, I have the isspro EGT & Boost. The diameter of the gauges are smaller than the hole in the mount(I can't use the hold downs because thy won't fix inside the mount), how is everyone else getting these to stay put? Also I will need to relocate the rear view mirror, how did anyone accomplish this?
easleyj1 said:
How much too small? Would a couple of raps of electrical tape behind the bezel do the trick?
Jonny
Electrical tape worked on my ISSPro's in my autometer A-Pillar mount... They must be just a tad bit smaller than the autometer gauges... The autometers I put in another truck fit perfect...
Diesel Manor said:
If the Ele. tape is too thick, try masking tape. Not sure where you purchased your ISSPROs from, but there are some questions that you may have when mounting them in the windshield mount. You can reed our FAQ page here: http://www.dieselmanor.com/installsheets.asp Click on the link titled: FAQ - Frequently Asked Questions regarding ISSPRO gauges
As it turns out I bought these from you. So since the gauge diameter is too small I will need to build it up with some tape. Is this correct?
