Gauge installation
who has a BD Short Shifter?
Where to buy Fuel?
I am planning to install DiPricol gauges in dash using the three hole dash plate. How do you remove the dash cover? Connecting the Boost and EGT gauge is not a problem. I will use a Turbo boost fitting from Piers Diesel Research for the boost gauge. I am not sure about the best way to connect the fuel pressure gauge. Geno's has some fittings and hose I may use. Advise please I have not bought anything yet.
Most kits come with a different banjo bolt that connects to the injector pump that gives you the fitting for the guage. Very quick and easy. Suggestion, get the isolator. That way you don't have fuel coming into the cab.
Gauges
Mbaston
Thank you for the reply. Looks like the best way to connect the fuel pressure gauge. The guage from Geno's comes together with a isolator. I just need to know how to get the dash cover off.
which part of the dash. Generally, the parts just pull off. Makes you nervous but the pop off. A couple pieces have a screw or two.
The panel you are pulling off has one screw near the trash bag holder. The lower section near the floor has two screws at the bottom. As mine is a 6 speed, my console is different so there may be some differences.
