gauge installation
I'VE GOT GAUGES!!!!
CB antenna ????
Well I got my isspro gauges and A pillar three gauge mount, put them in on Friday. It went very well and every thing works great. I'm getting about 19 lbs boost with a stock engine this truck really runs great. Thinking about the EZ edge for the next addition. Takes alot of talking to the better half, hope it's worth it. I am getting a little rattle out of the boost gauge but understand this normal.
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,354 LSD rear axle,Raven Magnum 8' cap.
Rich, I put the same gauges in last weekend. I have seen the rattle mentioned before but my guage hasn't made any noise like you described. Like you, I am seeing 19 lbs max boost. 19 lbs on a 50 lb guage looks kinda wimpy so time for some more parts to make MO'PAWAH!!
Sam
2001. 5 2500 QC HO 6sp LB 3. 54LS everything except leather, white/agate 2wd,WD air filter,Isspro,ME kit in the mail
Fordaholic-clean and Mopar'd since 10/05/00
[This message has been edited by Ram4Sam (edited 01-28-2001). ]
If you secure the tubing to the boost gauge with the wires in the a-pillar(tape them together), the rattle will go away. Or mount the boost in the lowest hole in the a-pillar.
Fred Swanson
Co-Owner
Canyon State Components, LLC
www.canyonstatecomponents.com
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, DTT's VB & TC
Thanks Fred I'll try moving the boost gauge. I had the MagHitech trans pan put on today And really have to work the truck to get a reading on the trans temp gauge. I have the probe in the pan for now looks like I will have to change it to in line. Who sells an in line fitting. Maybe a cheaper way to go than the entire line with fitting?
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,354 LSD rear axle,Raven Magnum 8' cap. Mag Hitech trans pan. Isspro gauges Apillar mount. Amsoil air filter.
To get rid of the "rattle" try cutting the nylon line about a foot from the engine and putting 6 inches of rubber tubing in. Sure got rid of mine.
DEBEEST, 99 QC 2500, SLT, 4X4, LWB, 5 Spd, Rhino Liner, Mobil Delvac 1 5W40, Auto Trim Design Runningboards, Les Schwab Wild Country Radial APTs, ISSPRO Boost Gauge and Pyrometer
I'm wanting to put some guages in my 99 QC 3500 and really like the A pillar mount. Can someone elaborate on the difficulty factor. Is it an easy job or does it take the better part of a day and alot of cussing? I've only had this truck for about a year and it's time to start the bombing process and guages are first on the list. Thanks.
