Gauge light supply ?
Air Horns
Ricksons : Wanted
Getting ready to install my Isspro pyro & boost gauges on a pillar mount. Just wondering if someone could please tell me the best place to wire in the light for the gauges.
Thanks in advance !
Charlie
2001. 5 3500 Quad Cab 4X2
HO, 6 spd, 3. 55AS, Jacob's brake, patriot blue, 22K Reese 5th wheel,Reese digital brake controller, Isspro pyro & boost gauges, Snap-On tool box
I recently did this on my 99. The gauge illumination fuse is in the interior (left of dash) fuse box. The correct fuse is #5,(3rd from left on top row). The fuse connection extender that came with the Isspro gauges was too big for my fuses, so I modified a spade sta-kon connector to fit along side the upper (load) end of the fuse. Be sure to tap into the fuse on the load side so that your gage lights are protected from shorts. The advantage of using this circuit, besides gage lights coming on with your other lights, is that this circuit is controlled by the dash light dimmer.
Keith Eilers, 99, 2500, 5sp, LB, QC, 4wd
Thanks Keith ! Should be warm enough this weekend to install my gauges. Took them out of my '93 and the pillar mount for the '01 just arrived. Heading for Florida on St, Patrick's Day towing the wife's 30' 5er.
Thanks again,
Charlie
