gauge light
transmission fluid
Trouble Codes
Hi guys. Installed boost gauge today. Looked for power for the lamp at the headlamp switch, found no power at all at headlamp switch. Suspect that this is a ground activated system? Where do I find switched power for parking light circuit or head lamps to illuminate the gauge? Thanks pagema
I think you could go off of the fuse box under the hood, there is a pretty good description of what those fuses are, but I like 2Rowdy pulling it off the radio... . shorter wire and it would be a cleaner install.
Hi guys, thanks for your information on the gauge light. This gives me a good place to go. Thanks again pagema
