Gauge Lights Not Working???
how much is a getrag worth ?
Gauges & Mounting Options
"Gauges" fuse looks good. Do I have a bad headlight switch? I think it must be dimmer-related, because my ISSPRO gauge lights are hooked into that circuit. Help?
So the only guages without lights are the factory guages? Your ISSPRO guages and tail lights, in the same circuit work fine?
If your ISSPRO guage lights and tail lights are working, it's not a fuse or the headlight switch. I would start checking all of your connections, especially the splice point where you tied the ISSPRO guages in with the factory circuit. I've had a bad splice come apart and do this.
Then check your ground, should be on the right side of the steering column. The Isspro guages and tail lights should have a seperate ground from the factory guages.
Hope this helps.
Tom
Thanks, Tom. I will check the splice point. However, the aftermarket gauges do not illuminate. That's what got me. All of the gauges work properly, and so do the head lights, but no dash lights.
Got it! Started pulling fuses and the 3A "Instrument Pnl Lamps" fuse was blown. Who knew that the cigar lighter lamp, where I spliced my gauge lights, was on that fuse and not on the Interior Lights fuse?! Replaced the fuse and all is well.
