Engine/Transmission (1998.5 - 2002) gauge questions
I've read alot of different threads about gauges and set-ups, does anyone have their fuel pressure gauge on an A-pillar mount?
Does anyone know if Isspro has a website?
I'm looking for EGT, boost and fuel pressure and want to mount them all on the A-pillar.
Which manufacturer comes the closest in matching the instruments on my '01?
Thanx for any help.
Mike
Mike... I have Westach Boost/EGT combo and a Westach Fuel Pressure gauge installed on my "A" pillar in a two hole mount. Good value, they look good, and no problems for over two years. Got them from Geno's... ;)
Can Westach gauges be used with Autometer A-piller mounts?
What is the 'right' way to hook up the fuel pressure gauge? Banjo fitting or filter? Is there a design problem with the stock banjo fitting that causes flow restriction? If so, what is the best way to correct?
Thanx,
Mike
