I am having mixed feelings about where to put the trans temp sender.
I was thinking of a Mag-Hytec extra deep pan with the sender in the supplied port but then the added 4 quarts in there would surely show a cooler pan temperature.
Another thought is since the factory pan is already pretty deep, why not just add a drain plug and sender port.
Is there a better way to measure true trans temp like a line out adapter where the fluid exits to the cooler?
What have you done on yours or seen on other trucks?
