Engine/Transmission (1998.5 - 2002) gauge sending units
2nd Gen Non-Engine/Transmission Growling Front End
Engine/Transmission (1998.5 - 2002) Torque converter slip
Just picked up my new gauges EGT, Boost and Electric fuel pressure. They are Autometer Ultralites. The wiring diagrams look straight forward, the issue im having is the locations of where to drill and tap for the sending units, i havent seen any on other trucks to even get an idea of where they will be located. Any help to get my 02 Ram gauged via words or even pictures would be excellent. thanks.
I just installed my EGT, trans, And boost gauges today. i drilled and tapped the elbow directly downstream from my turbo for the pyro. and i couldnt fint the boost bolt local so i drilled and tapped the manifold.
hope this helps
Ron
