NOT! :-laf
But now that I have your attention, I’ve got a question. I’ve been installing my gauges the last couple nights. I have all the gauges in a pillar pod, EGT, boost and fuel pressure. (mines a 5 speed) That end is all hooked up and finished. I have the EGT probe installed in the manifold and had no trouble. That works fine. The boost I just have to make the connection on the engine but lacked an 1/8” elbow. For the fuel pressure I tapped the banjo bolt on the pump and connected a 1/8’ flex grease gun hose from there to a device which came with the gauge called an isolator. (gauges are Hewitt brand). Then from that to the gauge with the hose provided. I assumed the isolator was to prevent the needle fluctuation from the fuel pump. If it is, it’s not doing its job because the needle vibrates 2 or 3 lbs like crazy. It’s a brass device about 3-1/2” long and maybe an inch or so in diameter. Is this not the purpose of this thing?
Should I just try the needle valve thing like has been discussed and forget this thing or maybe try a needle valve along with it. Opinions welcomed.
Tim
PS: What’s normal fuel pressures at idle, cruising, WOT? Looked like about 20 or a bit more at idle. Sound right?
Tim
