I finally go my gauges installed after 8 monthes with bombs, and I have a few questions. The boost gauge kind of acts funny in that it won't really move then jumps to 10 psi and then jumps again to 20 psi when under hard acceleration. Tops out at 30 psi with the boost elbo that comes with the Ez. Are these jumps like this normal or is there something wrong with my install? Also how much boost can I expect from a Ez and 275 Rv's if it is 1psi per 10hp then I should get around 32-33psi and still in the effective range for a Hx35 should I just plug the elbow or leave it alone? And when should you start seeing boost readings when you put the transmission in say 2nd gear , with moderate accel or just when you romp it
Thanks and sorry it's kinda long
Jared
Lovin' it every day now!
Jared
