At the same time that I installed a 16cm housing, I finally put some gauges on. Not thinking about it until later, I didn't have any "before" numbers for my gauges, to base the readings against.
Currently I get 18 lbs of boost at WOT. More usually 17-17. 5, but 18 is max. I haven't had a heavy load yet, but exhaust temp going up a fairly steep grade holds at 1150. Temp quickly decreases when I let off the throttle.
Also, with the smaller housing, when I've been going uphill and quickly let off the throttle, it sounds like the turbo is freewheeling. Is this normal? Will it tear anything up?
Thanks for the help.
