What is everyone using to seal the threads on the gauge sensors?
- trans temp and boost: I was going to use "sensor safe" RTV.
- EGT: I was going to use anti-sieze.
My trans temp sensor has only 1 wire, it grounds thru the sensor body. If I use the sensor safe RTV, will it still provide a good ground?
On the engine, I see some white caulky type stuff on the NPT plugs for the hot coolant on top of the cylinder head, but I don't know what this is.
Thanks,
Louis
Thanks,
Louis
