Engine/Transmission (1998.5 - 2002) Gauges
Engine/Transmission (1998.5 - 2002) PacBrake Mod
Who has the best deal on gauges and the a pillar? How hard is it to install a pyrometer, should i pay my local diesel shop to do this?
I would like to get the white faced gauges because they just look cool, what brands offer the white faces.
Thanks
Jeremiah
Genos garage had the best deal I found. I installed a Westach fuel PSI gauge in the dash last month, and I just ordered the A-pillar with Di-procal Boost and temp. The pyro will be next. Genos sells several brands with both the white and black faces, as well as digital. The gauges were easy to install. You can do it yourself I'm sure.
www.genosgarage.com
Genos has them beat by a couple of bucks each gauge. They didn't have the di-pricol listed. The ones I was looking at at the time were the autometer Z series.
Try www.usdieselparts.com , I found they are cheaper on some gauges but had a better selection and Genos cheaper on others, you might want to buy from both, plus Genos was cheaper on the a-pillar. I bought the ISSPRO marine EV series, white face with blue letters and pointer. As far as the install goes, depends on how mechanically inclined you are. Do you want to risk drilling with grease on the bit and using a magnet to fish out anything that falls through, do you want to remove the turbo and do it right, or pay someone? Personal call in my opinion.
