@jwinnie - Number I was not comfortable with, but I will say that the 2006's seemed to run hotter than what others were accustomed to with previous year models. There were MORE 2006/2007's that toasted #6 than other year models. The 2006's began a new CAN BUS and some other stuff that led to the 2007-1/2 6. 7's. Programming in the 2006/2007's IS different, all the programmer manufacturers will tell you that also. I live at altitude, tow a lot, steep grades, etc, so I experience higher egt's in that environment. If I had not had gauges I would have never known about those higher EGT's prob would have toasted my engine too. Of course, we do have a warranty for 100K, but who knows at what mileage of repeated high temps would the engine have given up the ghost??
I had problems with the rail relief valve beginning at 1K miles, continued regularly until 12K miles, and the valve was finally replaced by my dealer, have never had that code again. Every time I took my truck to them, they could not find the problem causing the code, they would just erase the code and send me on my way. They fed me some bs about starting the truck immediately when I turned on the key, the reason I was getting the code was that I was waiting too long to start my truck. Well, I bought my truck in Feb, was waiting on the grid heater . . didn't make sense to me ??? Then, the problem persisted into good weather and I was starting it immediately when inserting the key . . and the best part is that it would throw the code when driving around. I have both the fuel pressure and rail pressure gauges, installed the fuel pressure gauge right after I bought my truck, the rail pressure gauge later on when they came out. My gauges actually helped diagnose the problem, I noticed the fuel pressure and rail pressure drop, then the code would throw. After I told them that, they tested my fuel pump, found no problem with it so they replaced the rail pressure valve.
I bet if I had not had the gauges to be able to see it happening, I'd STILL be playing the dealership game without any results.
I am a firm believer in guages, most all of the factory gauges are glorified idiot lights and worthless for the most part, the damage is done by the time you get an idiot light. IF a diesel didn't need the kind of gauges we install from the aftermarket, then the big rigs would not have them either. When you work a truck and use it like a truck and it's not just a pavement queen, you need the best information you can get.
CD
